Mavic Pro Won't Connect to Controller or PC
Mdeblasi1991
Florida
The drone will not connect to either of my controllers and when connected to the PC it is seen as an "unrecognized device" while being continuously detected and undetected. Is there a way to update the firmware from either of the SD card slots? Thanks.
Are you using the DJI assistant thing if that is required, and the correct assistant at that?
Are you using the cables that came with the Drone?
Vivek Priyadarshi
