Mavic remote
The controller for the MPP, just doesn’t do the drone justice. The drone does such a solid job, and you look down at the controller and it looks like a toy, but hey, it does the job. And welcome to the forum.
Regards
Reactions: Cyborg5000
Is there any way to get the charging port changed to like a C port? Seems like that would be easy?
The board inside the controller that has the charge plug is somewhat easy to remove once you get the controller apart. Some very small wires and connectors that you need to watch out for. As for changing the connector to a c style, I personally would not make that attempt. Circuit board soldering on something that small would be a bit tricky.
Thanks, it would be so much better
BigPapa98
