The P4P flies faster with sensors on.Turn off obstacle avoidance sensors and it will fly faster as it does not have to worry about anticipating obstacles.
Hmm... both DJI products with sensors?!? How fast does your Mav fly in P mode with sensors?What has that got to do with your OP.
Give me an apple to apple then. What's your Mav speed in P mode with sensors on?This is true! The Mavic does not. Apples to Oranges comparison.
Don't fly with them as I stated do not with the 2 ether except when it comes on in different modes .Hmm... both DJI products with sensors?!? How fast does your Mav fly in P mode with sensors?
You should check your Phantom again.The P4P flies faster with sensors on.
Wait... whaAat?Don't fly with them as I stated do not with the 2 ether except when it comes on in different modes .
13.5 metres/sec (31 mph) with obstacle avoidance enabled
16 m/s (36 mph) with OA off.
If your Mavic is only making 11-12 mph in P mode, there's something wrong.
Yes, hence the reason for my postAre you sure you're giving correct numbers?
Maybe reading metres/sec as mph?
Wind or not, the Phantom flies faster with OA disabled.Take the P4P out of DJI's "ideal conditions" and add in some wind, and no checks needed. Performing as designed
Yes , a flight log would be a good idea. If you want to provide it here then this is the process. That way the log can be dissected for abnormalities.
DJI Flight Log Viewer | Phantom Help
Nothing because the file you've attached just produces unbelievable crazy numbers.What do you see causing the issue?
