Mavic to 2020 DJI FPV Goggles
afreakofnature
South Dakota
Anyone figure out a way yet to hook up the new FPV goggles with a Mavic Pro with or without the Air Cam? I don’t really wish to have to buy the old white goggles and the new ones especially since i plan on getting the new ones to start true fpv flying. Would be nice if there is a hack or mod to do this.
No one has tried this? Probably why I can’t find anything on it. The controller has two USB outs so you would think that maybe one could work as an HDMI out with some type of heck if not legitimately. Maybe this should go in the Mavic pro section.
Forget about it. The Mavic Pro is using the Ocusync protocol and requires specialised software running on the goggles, emulating the GO4 app. So the white and black DJI goggles are running a stripped-down version of GO4.
In contrast the newer FPV goggles are using a very special low-latency protocol which is very different to Ocusync. In fact, actually there is no available DJI drone which is compatible with the FPV goggles.
If you want a cheap way for flying the Mavic Pro with goggles, then consider buying the Litchi app and a set of Cardboard compatible goggles.
marcusjohn3684
