- Joined
- Jul 13, 2019
- Messages
- 5
- Reactions
- 0
Hi Folks, I work in archaeology in the Andes (6,000 meters max) so the question is what is the maximum altitude for a Thunder Drone? I could be working at 5,500 meters or more where the air is quite thin.
Thunder Drone??Hi Folks, I work in archaeology in the Andes (6,000 meters max) so the question is what is the maximum altitude for a Thunder Drone? I could be working at 5,500 meters or more where the air is quite thin.
He wasn't asking about flying up 5500 metres from sea level.You wanna be careful going up that high
I'd suggest that you swap the stock DJI propellors on your Mavic Pro, for Master Airscrew 'Stealth' prop's designed for the Mavic Pro. These prop's are more efficient (provide the same lift at lower rpm), and therefore should get you a few more metres on the service ceiling spec'.Hi Folks, I work in archaeology in the Andes (6,000 meters max) so the question is what is the maximum altitude for a Thunder Drone? I could be working at 5,500 meters or more where the air is quite thin.
No, he was asking for worse: 6000m above ground that is probably already way above sea level.Thunder Drone??
From the specs for the Mavic Pro: Max Service Ceiling Above Sea Level 16404 feet (5000 m).
But the Mavic Pro has been flown higher than that.
You do know that you can fly from up in the mountains?No, he was asking for worse: 6000m above ground that is probably already way above sea level.
Should be ok. Like has been mentioned get the Master Air Screw Stealth props which have a higher pitch angle than the stock props, this means the props won’t have to spin as quickly to get the same amount of lift as the stock props. Keep an eye on your drones internal temperature and let it warm up before take off since it’s winter there now it will be very cold and also keep an eye on the windHi Folks, I work in archaeology in the Andes (6,000 meters max) so the question is what is the maximum altitude for a Thunder Drone? I could be working at 5,500 meters or more where the air is quite thin.
Thanks for the info. I appreciate it.You wanna be careful going up that high - the drone will only descend so fast - your average flying speed is about 33 km/hr (regular mode) but your descending rate is much lower - if you go that high you may find yourself in freefall after the batteries run out - maximum descending rate has to be about 3 meters/sec (10.8 km/hr) or 200 feet per minute - I wouldn't try it.
Thanks. will do.Should be ok. Like has been mentioned get the Master Air Screw Stealth props which have a higher pitch angle than the stock props, this means the props won’t have to spin as quickly to get the same amount of lift as the stock props. Keep an eye on your drones internal temperature and let it warm up before take off since it’s winter there now it will be very cold and also keep an eye on the wind
Will do. Thanks.Other people have talked about using drones at higher elevations and the drones work fine . Flying times will be shorter than flying down near sea level . Post some cool pictures if you get a chance .
thanks. I appreciate the heads up.I'd suggest that you swap the stock DJI propellors on your Mavic Pro, for Master Airscrew 'Stealth' prop's designed for the Mavic Pro. These prop's are more efficient (provide the same lift at lower rpm), and therefore should get you a few more metres on the service ceiling spec'.
[I'm assuming that you have a Mavic Pro - as that's the part of the Forum you have posted in ...]
DJI Mavic | STEALTH Upgrade Propellers
Upgrade Propellers for DJI Mavic - High-Performance Propellers from Master Airscrew. Low-noise, quick-release, color-coded props for better handling and silent operation.www.masterairscrew.com
Keep in mind this is pushing the operational limits of the aircraft so you’ll really have to be mindful that you’ll be pushing it and so I would plan on landing with 30-40% battery remaining.Thanks for the info. I appreciate it.
The Andes are 6k, I'll be working at 4-5k. I sure that my altitude from where I stand would be much less.
