Michigan member Bravocopter
Thank you for the approval.
Hello, I live in Lansing MI and fly a Mavic 2 Pro but not nearly enough to be considered good but looking to improve on that. I joined MP to learn and share information with other pilots and members here on the forum. Fly safe
Welcome to the forum, from Westland Mi. Just outside of Detroit.
Fly Safe
Have you found good places to fly in and around Lansing? I was at Crego park last weekend.
Hi Randy,
I live in a controlled airspace like 1 mile from the airport so I have to get LAANC approval and unlock approval to just fly it in my yard so I don't get enough practice and I don't usually fly right here and around here that much. I will travel and take videos like surrounding towns like Grand Ledge, Mason, and then even a lot more out of state on vacations or trips. I try to plan my vacations with a designation that would have places with good drone video footage
Reactions: MA2 317 and Droniac
We loving from Long Island NY. I think we all have the same in common. I check search, since most all things are well covered although through progress and specifics leaves a great forum to teach, question, share and have a laugh occasionally. At all experience levels. Flysafe, Godspeed Droniac
Welcome from Royal Oak!
Mike107
Reactions: old man mavic
Welcome to the forum, great bunch of people, friendly and helpful.
Greetings from Birmingham Alabama, welcome to the forum!
Welcome from the Hampton Roads area of Virginia, USA. I fly a Mini 2 and I know the excitement you are going through…
We have a Member's Map in the Upper Right of the Title Bar, Tap "Members", Tap "Member's Map" Members map
There are a couple of Legal Things you may need to do…
You will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone. I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Flyer.
Link to the Pilot Institute Web Site (FREE…) FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Link to the FAADroneZone (Optional for Drones under 250-Grams…) FAADroneZone
Below is the link to all of the downloads offered by DJI for the Mavic 2 Pro Zoom. You will also find the 69-page User's Manual, in case your Drone did not come with one.
Happy and Safe Droning…
osje
