Micro usb to lightning cable a anyone recommend a good brand
Here are a few Micro USB to Lightning cables:
71063
71064
A reverse Micro USB cable would be a better option since you're going to attach it to the left side of the remote controller. This one probably isn't quite long enough:
71065
Figure out which cable will work for you length-wise and then check out the reviews on Amazon (or wherever you're shopping). You'll likely have a good experience if the cable you choose has positive reviews.
Thank you msinger
So many brands available. Any one or two better than the others?
Yes.
Very easy to find a cable that fits the hole, very difficult to find a good one that fits, cable quality does vary greatly. Apple cables require a chip built in, if not it will not work reliably, if at all. Yep, the chip must be licensed from Apple, that’s why they cost so much. ?
I guess the longer cables would work with iPads. But I only have a full-sized iPad so holding it and the controller would be unwieldy.
giraffe
