Hi. Sorry, I should’ve been a bit clearer. I’m using a regular usb plug and have also used an apple plug together with the included usb cable. It’s the leds on the drone. When plugged in it charges normally... led 1 comes on, then led 2, then led 3 all flashing as they should etc. All appears normal but the 4th led does not come on. When charging has finished all 3 leds remain on but still not the fourth? The app shows 98% on the drone. Also, I am aware of the different usb plugs (watts) but I’m using the plugs I used on the previous Mini and although it took nearly 5 hours it charged fully with no problems. Thanks for replyping.Is this as seen by the LED's on the drone or triple charger?
Do you mean only leds '1, 2, 3' illuminate or perhaps that leds '1,3'4' illuminate but 2 does not etc.?
Do all 4 LED's illuminate in the sequential flashing as it charges?
What does the app say the charge is?
I do appreciate all the replies and help. Thanks. It will definitely be going straight back. It’s a complete waste of time. It’s a bit sad but I wouldn’t buy another. I understand it’s only one led light out but if I wanted to sell it in the future it would be a problem. Would you buy one if the seller said one of the battery lights isn’t working? Thanks all and goodbye.With that description I would suspect a dead LED, personally I doubt I would return the drone for just that. Since your other thread contains just "Abcdefgh" no one knows what the other problem is, nor how serious it is, but obviously the choice of whether or not to return it is yours.
Well, you're giving up on a very reliable great drone. I just wonder if when you said " I’m using the plugs I used on the previous Mini" it was also a Mini 2 ? I haven't had a Mini 1 so don't know if there is a difference in charging current or if it matters. Also, you evidently bought from an individual, not new from a store, so that may be why the previous owner sold it and not the fault of the drone perhaps. Hope you won't miss the greatest feature of this drone, a very real portability with still great features.I do appreciate all the replies and help. Thanks. It will definitely be going straight back. It’s a complete waste of time. It’s a bit sad but I wouldn’t buy another. I understand it’s only one led light out but if I wanted to sell it in the future it would be a problem. Would you buy one if the seller said one of the battery lights isn’t working? Thanks all and goodbye.
