Mini MINI 2 GPS ACCURACY TEST VIDEO COMPARISON WITH MAVIC MINI
From 0:33 to 1:15, 100 height meters, 16x video forward you see Mini vs Mini 2 stability
That's not testing "GPS accuracy" because from that height, you cannot identify differences and they are masked by camera movement anyway.
You get a good idea of GPS accuracy from the specs DJI provide, and they are identical for both drones.
Hovering Accuracy Range
Mavic Mini
Vertical: ±0.5 m (with GPS Positioning)
Horizontal: ±1.5 m (with GPS Positioning)
Mini 2
the stability in flight of a drone is given by the highest number of satellites received, Mini 1 in Italy with GPS and Glonass receives 15-18 satellites, Mini 2 with GPS, Glonass and Galileo receives 23-25 satallites ... the title of the video is this "DJI MINI 2 WITH GALILEO IS MORE STABLE THAN MINI ?" stability occurs in flight with the micro-movements of the camera otherwise they are all very stable ... I'm sorry you didn't understand the video...
BEST GREETINGS FROM ITALY
STAY SAFE ?? ?
STAY SAFE ?? ?
Once the drone has enough satellites for good location data, having more satellites doesn't make it any more stable.
Either drone could achieve it's maximum stability with 6-10 sats.
With the drone 30 metres up, and with the camera gimbal moving to stabiilise the image, it's just not possible to tell how much either drone might be moving.
The video looks very good though and well made.
ironwingstudios
