Mini 2 help needed
Laggard
Los Angeles
Just got the Mini 2, setup, powered up, firmware updated, but am told that there are either no satellites available or the signal is to weak to hover safely. Went outside and no change. iPhone app shows a dozen satellites overhead.
So I’m stuck with a brand new drone that I can’t use.
Any ideas? Thanks.
  • Haha
Reactions: tlswift58
So in the Fly app in the upper right corner you have white satellite icon with >12 satellites and app does not allow you to start? Are there any messages (screenshots would be helpful)?
I am a bit taken back that your wondering why you had no sat signal lock in your home, so you went out side to check? You do know how they work, because just because your outside doesn't imply GPS Lock as well? Regardless there is a system built in for indoor flying if one is so inclined and has sufficient skill set.
Any ideas? Thanks.
There is, of course, no signal for GPS normally under any roof.
Indoors I am not surprised you get a no GPS warning but as has been mentioned there is a backup system (VPS?) that uses downward looking sensors to 'stabilise' the drone.
Providing there is sufficient light for it to work the latter is VERY good, cm perfect for me.
Perhaps, if you read the screen notifications carefully you may find this is available to you. (I forget precisely what I see, as per what follows.) A video recording screen capture app is VERY handy for 'capturing' these pop up messages.
When I fly my MM indoors I invarialbly get the warning of no GPS and then subsequent warnings about lighting and I have to confirm that I acknowledge (or something ) the warnings before my MM will fly.
That probably sounds vague but this, indoors, is now a routine procedure for me and, indoors, I no longer read the warnings providing they come in the correct sequence. Once the drone is in the air there is sufficient light underneath it for the VPS to work. (there is a single ceiling mounted light 'bulb' where I normally fly indoors so the drone very much sits in its own shadow)
With regards to moving out doors, it can take time for the drone to 'gather' sufficient satellites and for me, just outside my house, this could take minutes. I normally lift off before this and raise the drone to between 12 and 15ft so that it has a much less obstructed view of the sky. It normally gathers satellites much more quickly when up there. Note, this is a largely vertical climb. If it still doesn't gather sufficient satellites I will move it a few ft towards the centre of the garden.
This all uses the VPS to maintain 'stability'. If you have neither GPS nor VPS the drone reverts to ATTI and that is an entirely different ball game and should be avoided as it requires significant skill to use. (I do not have that skill.)
With regards to
are you talking about the fly app or some other app on your phone?
Correct. And when you go outside, it can take several minutes for the GPS receiver to lock on to the satellites for the first time after a long period of non-use.
Leave it outdoors, powered on, with a clear view of the sky for 10-15 minutes before declaring that the GPS isn't working. Once it gets a good lock, it should acquire the satellites much faster on later flights.
Take the drone outside where it has a clear, unobstructed view of most of the sky
After two minutes if it's still showing no satellites, there is a problem with the hardware and it needs fixing or replacing.
Many things could be happening - most of which you have not told us. While having a clear overhead area DOES NOT guarantee a satellite lock. I've been waterfalling with a clear overhead, but inside a bowl type area and NO SATELLITE / GPS LOCK till I go into a nice clear area. Sadly, the drone does not get very high and it's kind of nerve racking flying over boulders and water a few feet below. Also sometime the terrain increases, which adds to the excitement.
Best advice is to go to a park or field that is WIDE OPEN - no trees, no obstructions like building, mountains, etc - IF POSSIBLE - and turn everything on. DJI also has a sequence of turning on the controller / drone which I've found doesn't make a difference, but give that a shot.
Start the drone, lift off as high as it will go, and wait a minute or two for it to try and get a lock. If it won't under those conditions, then something is wrong and give DJI a call or email for help. New drone should work from box and they may have more help / info for you.
Thabo
