Mini 2 Set Default Speeds
Lastrexking
Yorkshire, United Kingdom
Is there a way to alter the drones speed in different modes, specifically Cine?
I’m fairly sure that on my old Mavics (I’m think the Air) that it was possible to change the default maximum speed?
I've checked the manual, and been through the app but can’t find anything.
Why would you EVEN want, or need to do this?! Sometime folks just feel the need to mess around with things too much and then wonder what happened when things go wrong. Stop obsessing with the settings and just enjoy the drone for what it is.
Reactions: Peshoa
Because I’m partially sighted (I only have 40%) vision. So, I’d like to be able to change the speed parameters in Cine mode to something slower so that it’s one less thing to worry about. It was possible on the Air, so I don’t think it’s unreasonable to ask if the Mini2 can do it too.
You can change the angles, yes. Not really up, but since he was mentioning cine which is usually considered too fast the goal was more to reduce it (confirmed in the reply) which is no problem.
Phly858
