Mini 2 speed not maxing out
OldmanTom
Kelowna
Mini 2 is often maxing out at about 24 mph. Display showing in Sport mode. Sometimes switching to Normal then back to Sport fixes problem and get speed of about 35 mph. Temp been about 90 and at 1000ft elevation. Is this common problem? Not sure if heat affecting performance.
Reactions: CLAYB.7
What about wind?
No, it's not a common problem.
One possible solution ...
If you are launching in Sport Mode, the drone won't actually be in Sport Mode.
You need to set the flight mode after launching.
Okay, that may be it. Will try and let you know. In response to other reply, no wind, big field, both directions. Thks
M5P
