Mini 3 Motor/Engine Trouble
If that is what is happening,(very strange) Are you using a prop tach? Its not a motor issue its an ESC issue. You need to replace the ESC Board. but be sure about it (sounds strange) check that the props are correct and in the correct place. (cw/ccw)
Welcome to the forum From Bakersfield!
Stany
