DJI Paladin Posted at 5-10 16:33I posted the wrong video while ago. This are the tentative specs for the mini 4 as per few youtubers.
That's pure fiction and and isn't at all believable.I posted the wrong video while ago. This are the tentative specs for the mini 4 as per few youtubers.
I have been flying my mini 3 for quite a while and I have not noticed any fogging issue. You are the third person that mentioned that. When does the lens become foggy if you do not mind me asking? As far as the heating issue, I think there is no solution since there is no fan, I do not know if the mini 2 heats up since I do not own one.They need to try and do something about the overheating leading to shutdown & lens fogging issues before they even begin
to think about a mini 4.
That is what I thought, if they pull this off, this drone will be a must have.That's pure fiction and and isn't at all believable.
It appears to be made by someone who knows very little about drones, but wants Youtube clicks.
If they pull what off?That is what I thought, if they pull this off, this drone will be a must have.
The two-inch sensor was what caught my eye too because there is no such thing.The two-inch sensor was what caught my eye, true or false. At this point, with all the advances in technology it would not surprise me if DJI can come with it.
DJI does not make image sensors. And as Meta4 pointed out, there is no such thing as a 2 inch sensor.The two-inch sensor was what caught my eye, true or false. At this point, with all the advances in technology it would not surprise me if DJI can come with it.
The biggest sensor using inch size naming is a 1.5 inch sensor that was one used in an old Canon camera nearly 10 years ago.Technically if it exist it already exist by a known name. Depending on the aspect ratio, a 2" sensor would be either the already existing micro - 4/3 as found on a mavic 3 (which isn't going to be in a mini) up to a APS-C size sensor.
To me, it's more of a dream sheet, rather than reality. Plus "early 2023?" If something were coming out it might be Sept - Nov.This is not believable at all.
But from what I have heard, they will release a non-pro version of the Mini 3 pretty soon, however I can't say it for sure.
Will it have a 2inch sensor.I can sell you some Mini 5 leaks information if you want..
