No and you should preferrably disable Wifi to avoid interferences with the remote and therefore range issues.
I know the Mini doesn't need an Internet connection on the fly. does my phone need to have Wi-Fi enabled? Can I fly without wifi connection? sorry confusing questiongoogle translator![]()
I didn’t know to do that. Does anyone else disable wi-fi?No and you should preferrably disable Wifi to avoid interferences with the remote and therefore range issues.
No need enable your phone wifi
The wifi connection is just between remote controller and aircraft
I believe they put their phone into "airplane" mode. Can someone confirm this? I personally don't and haven't had any problems but will keep it as an option.I didn’t know to do that. Does anyone else disable wi-fi?
You should still have the map window, it just won't have any terrain data unless you cached it first using internet. It should still show your flight path and a line between AC and HP.A bit off-topic, but close.
I use an iPhone7+ with no SIM card with my controller so when I disable WIFI I lose the Google Map window (no way to get the Google Map data) so my workaround is to tether the iPhone7+ with no SIM to my cell phone via Bluetooth. This works fine and I don‘t notice any interference to the drone.
i use airplane to minimize interferences, though there is a bug with DJI Fly app on samsung devices that when switching to airplane mode buttons for photo and video on the RC stop working and you cannot change flight mode on the app, only workaround being restart of the app...so in case you have such issue, have it in mind, it might be better not to switch to airplane but manually switching off mobile, bluetooth and wifi, or switch to airplane mode before opening the app with enabled wifi and bluetooth and after app start manually switch them off....
it is on exynos processor so far that I have seen, but it was also reported on other forums on other brands like sony, so probably it is not only that.... If you don't have it better for you...i have it every timeAre you sure ?
I'm not suffering that button issue/bug when flying my Mini with Samsung Galaxy A40 (android 9) at airplane mode.
R.
