Missing photo resolution setting
ICHOTT
As per title guys, I seem to have lost any settings for photo resolution!
see the 3 pics, I can see it in video setting but in photo whether set to
Pro or Auto there is no option to choose/change resolution or FPS
help please??
I assume this is the mini 2 and you mean aspect ratio not resolution?
No Brett, oh yes it is the mini 2 but it’s the photo resolution option of eg 4k/1080 etc that’s missing
in the pics you can see in the one set to video that the RES&FPS of 4/24 is clear, but the other 2
pic set to photo/pro and photo/auto the are no RES&FPS option.
I was looking at youtuber vids those guys still have eg 4K 24 FPS showing ??
im on 1.4.8 and firmware all updated to.
Those are video resolutions. For photos the mini 2 can do
4:3: 4000×3000
Or
16:9: 4000×2250
Also, there won’t be any FPS settings for photos. FPS stands for “frames per second” and since a photo is a static image this setting wouldn’t apply to photos.
Thanks Brett, doh! Re FPS, clue was indeed in FPS. ??
senior lapse of err something ???
Reactions: brett8883
help please??
That is where I am. The You Tube with a foreign man narrating the video uses Auto button but I use the Pro button and never see the screen that the narrator does. I just need the resolution improved for still drone shots of property at about 150 feet. I am miffed right now.
It is at max resolution at all times. Only aspect ratio can be changed, as stated above. Use auto focus, see if it improves. Make sure the lens is spotless!!
A lot of people are confused about what resolution is.
I'm not sure that resolution is really the issue in this case.
What's the problem you want to solve?
Perhaps it would be helpful if you post an example to show it.
JHW Imaging
