MM Fly More Case Shoulder Strap
Scottalmas
Bonita Springs, FL
For anyone else out there that was wishing that they had a shoulder strap for their Mavic Mini Fly More case, I just received this via Amazon and it is hard to imagine a more perfect match.
CoolBELL Adjustable Shoulder Strap with Metal Hooks for Laptop Bag/Camera Bag/Duffel Bag/Shoulder Bag (53 Inches, Grey)
by COOLBELL
Stay safe all!
Reactions: scro
I robbed a very similar strap off an old compact camera case I had lying about. Makes it very easy to carry on a hike out in the countryside.
I made a harness to fit around and under the case and attach that harness to a camera strap, it's not the neatest looking thing but it works. Having done that I did wonder about a net bag with suitable clips for tha camera strap. Alternatively if the case lining could be temporarily removed, straps could be attached directly to the case itself.
There is a webbing loop at each end of the carry handle and I did wonder if DJI intended them as attachments points for a strap but as I don't know for certain that that was their intended use and I do not know how securely they are attached to the case I decided not to use them.
I'm pretty sure those loops are for fitting a strap. That's how I've attached mine. The loops on my FMC case are firmly stitched in with the webbing handle so if the handle holds the weight OK then so will the loops :)
Gerryfaz
