MM remote controllers
andy1349
Glasgow UK
I’m looking for some info on remote controller for Mavic Mini.
if I purchased one from the US, would this be compatible with my UK version one.
thanks in advance.
thanks in advance.
There are two different versions of the MM RC
A CE aircraft will need a CE remote controller
The FCC controller only transmits in 5.8ghz frequency so it's not compatible with a CE aircraft.
I don't believe it will even bind with the AC.
I have both the FCC and the CE remote but only the CE aircraft. I can definitely tell you that the FCC remote will not pair/bind with the CE aircraft.
Thank you lannes and Old Guy. I was getting mixed messages on eBa. Some saying it would work fine. I will wait and see if I can get a UK version.
If there is any doubt, ask to see a photo of the label on the back. The RC Controller you need will be clearly marked with large 'CE' letters. If its marked 'FCC' - then that's for the USA.
coregambit
