monitor hood for phone
Mike Cumens
Phila. PA
Purchased hood for mavic pro (pgytech) but rc cable from controller to my Samsung phone is too short. What is the best way to remedy this problem?
Get a longer USB cable and connect it to the bottom of the remote controller. A 12" cable (like one of these) should be sufficient.
Didn't realize you could use USB connection on bottom of controller. Thanks for clearing it up. Thanks again
And when you do that you must disconnect the USB micro A, Otherwise nothing happen, you can’t connecting.
You do want to be careful with that side connector port. Reeeeally cheap, and can be damaged easily.
I use a magnetic charging cable, with the little magnetic connector always in the side connector, saves the wear/tear on the side port.
Big Mouth Media
