- Joined
- Oct 3, 2017
- Messages
- 1,238
- Reactions
- 849
What speed is the most efficient for flying time?For instance,when getting a drone back to takeoff spot when you've ignored low battery warning.
Thanks Chris.I don't ignore it but was curious as to what the most efficient speed is.The best possible technique to use here is to return to home without ignoring low battery warning.
You can do estimations by looking at your distance from home point and make your own calculations (same distance to return), but you can be bit by longer return times when you hit a head wind (or anything else that uses more battery, such as avoiding an obstacle or dive-bombing bird) and find the aircraft landing very far from HP when it force lands at critical low battery levels.
So I've learned to not put myself in that situation. Thankfully, we have TWO levels of low-battery warnings that keep me from doing that.
Chris
This question of the best speed for maximum range has come up several times in the last few years. I recall that what has appeared to be the most substantiated answer has always been the maximum speed range in normal mode.Thanks Chris.I don't ignore it but was curious as to what the most efficient speed is.
Excellent point. I'll look forward to comparing the RTH speed to the max normal mode speed....look at the speed your drone is using in its return to home. The Drone is programmed to use the most efficient way to get home.
Yes but, it will do those calculations without knowing the difference in wind speed for the return trip, which is one of the reasons why our return warnings have buffer time.The Drone is programmed to use the most efficient way to get home..including throttle movements.
This has been tested many times and the speed that will give the most miles/battery is max speed in Normal Mode.What speed is the most efficient for flying time?For instance,when getting a drone back to takeoff spot when you've ignored low battery warning.
If you are referring to the drone's speed in auto RTH, this is a myth.look at the speed your drone is using in its return to home. The Drone is programmed to use the most efficient way to get home..including throttle movements.
The optimum airspeed for maximum range isn't affected by what the airmass is doing.Yes but, it will do those calculations without knowing the difference in wind speed for the return trip, which is one of the reasons why our return warnings have buffer time.
Speed in RTH Mode is slower than the speed for best "fuel economy" and in a critical case could result in the drone running out of battery before getting all the way back to home.
Thank you!IThis has been tested many times and the speed that will give the most miles/battery is max speed in Normal Mode.
One last point which I am surprised no one has made. Before takeoff, as a component of your checklist, set your return to home altitude to as low as is safe. Wasting battery by climbing to an unneeded altitude is going to take time and energy.What speed is the most efficient for flying time?For instance,when getting a drone back to takeoff spot when you've ignored low battery warning.
