Hello all
I hard crashed my drone and broke two of the wings. I then ordered two new parts from cloudcity and attempted installing them myself.
I was successful in replacing the rear hinge and routing the wires, however, after I installed the new wings, their led lights came on however the motors did not dance at boot up.
All 4 LED lights went red.
To trouble shoot whether the new motors are bad, I soldered on the broken ones, those as well did not dance on boot up.
I believe I might have damaged the ESC board during soldering. Is there a way I can confirm whether I damaged it? For example, can I use the volt meter is some way to confirm?
I did confirm the new motors beep when I test for closed circuit.
I actually worked on reattaching 3 wings.
The red areas did not power the motors.
The green area powered the motor just fine.
I had to work on the 3rd to replace its broken hinge
