Move the label
Janne Swede
Should change the upper shell of my Mavic Pro Platinum, does anyone know how to move the label with information about the drone to the new shell?
use a hair dryer to soften the glue then slowly peel back from one corner, keep using the hairdryer
Reactions: THE CYBORG
If the heat thing doesn't work what about soaking in WD40 and then if the label lifts, clean of the WD40 with isopropyl alcohol and stick the label down with fresh glue? No I haven't tried the entire procedure but I have removed labels via soaking in WD40, just test a tiny area first to see anything reacts badly to WD40
mahasingh
