Drone not pairing
siedlik
UK
Hello,
I bought a used AIR 2, that had props damaged and a tiny crack on a shell arm, and I'm trying to fix it.
When I turn on the drone, I got a
- prop movement
- cooling fan on
- sound that the drone is on I think
- Gimbal is not moving
- Can't pair the drone to the remote
- No lights on the arms
I would assume the drone felt and something happen to the main board.
GPS module is getting 3.3 volts
MainBoard is getting 11.4 volts, 3.3 volts and 1.0 volt.
Are there repair schematics for air 2 somewhere?
I got the drone cheap, so I think I will just sell for parts, as buying new mainboard is not worth it.
Welcome.
Whilst the drone possibly is a brick, if the mSD card is still in the drone remove it and see what happens when you switch the drone on.
Reactions: Cafguy
If you've already got the shell open (if you're testing voltages, that seems very possible) get a good set of magnifying loops and check all the micro connectors are still properly seated. With collisions, they are usually the first thing to jolt loose.
Reactions: Cafguy
Why not get an estimate from DJI you may get a refurb air 2 for a cheap price.
mikysbm
