Movements are Stronger than normal
ccoltmanm
When I first got my pro it would have a gentler bank when I moved it. Now, the thing nose dives when I tap forward and points to the sky when I go backward. Any reason why it does this all of a sudden and how I can fix it?
I have sports mode off, but it looks like it is on when I go forward or backward. Sliding left and right are bad too, but not horrible. Sometimes, the gimble can’t handle the violent movements.
You can adjust the settings in DJI GO to smooth out the Mavic's movements. Here are a few videos that discuss those settings:
It is possible that a firmware/software update changed your settings. That's why you always check settings after an update.
Yes, the gimbal is slow to react to sudden yaws and pitch movements. That is by design.
You can try using your sensitivity settings to customize the feel of your aircraft:
Reactions: macoman
Irish_Sinner83
