moverio update firmware
If you are trying to update the OS on the Moverios, then fire up your glasses, go into settings, then scroll down to "system", and you should find the "update" button.....
If it other than this, need more info...
Hi Thanks. I need to update the 1.1 firmware of the BT-35E box to the latest1.2 firmware.
On windows 10. Please see here:
Firmware Release Note - Documentation - BT-35E - Technical Information - MOVERIO - Epson
So with the process you get all the way up to step 5 without any problems and then you get the "No device found" error message ?
You need to go into the "device manager" and if there is a problem with your device (the interface box) , there is usually a yellow triangle an or question mark etc. when there is a problem next to the device.
Then you'll need to try and update the usb driver to support the connection of the Epson Interface box
I get to step 5 but don’t see device is ready Just command prompt window and device not found error box
So you get this message ?
Have you tried it on another PC ?
Grt001
