MP3 flight log
Hello from the Crossroads of America Andy carley.
Someone with more knowledge than me will help answer your DAT log questions.
There's a handful of members here that really know how to read the logs and can explain how to retrieve them if possible. Some files may be encrypted and can't be accessed.
You might try the search engine (top right magnifying glass) and look for an answer in the mean time.
Good luck and welcome to the Forum. :cool:
Hi there & welcome to the forum 👋 :D
This is what's stated on Phantom Help...
Read up more about flight logs in general here --> Mavic Flight Log Retrieval and Analysis Guide
In general & especially for todays newer DJI models it's only one log (of the 3 different types available) that can be accessed by us consumers... that is the mobile device stored .TXT log.
For some newer models the mobile device stored .DAT log can be accessible... a tool like CsvView is then needed, it's free & can be downloaded here --> CsvView Downloads
Hi chap's newbie here from Dublin down under. Got me an MP3 pro + RC pro and I am trying to view a flight log ,how do you view the. Dat files in something like phantom help.
You don't .. you view the .txt file in the Phantomhelp log viewer.
Your flight data is in the controller at:
Android\data\dji.go.v5\files\FlightRecord
Welcome to the forum! :)
You can decrypt and view your TXT flight logs using these log viewers.
Forget the DAT files on the drone they are almost certainly encrypted.
If you want the DAT's from the controller then you will need to ensure that the controller is NOT "syncing"/uploading logs with/to DJI.
Once you have found the location of the .txt flightlogs you will see a folder named MCDatFlightRecords, the DAT's are in there.
You need to down load CsvView or DatCon from CsvView Downloads to process a DAT.
Since you live in Australia, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Your use of the term "MP3 Pro" does not indicate which of the DJI Drones you have, the Mini 3 Pro or the Mavic 3 Pro, so I am including the links to both models…
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro and the Mavic 3 Pro, including the User Manuals
After you read the Manual that applies to you, read it again, you will be surprised what you missed the first time and you will be better prepared for that first "scary moment…"
Fly On and Fly Safe…
Oh, by the way, this might help...
Sorry it's a mavic 3 pro and I love it
Reactions: LoudThunder
Not a problem, I'm glad for you, read the manual and it will tell you stuff you never imagined and be sure to watch YouTube videos on setting your bird up. The manual is great, but seeing it on a video is sometimes so much clearer...
Roel Hopstaken
