MPP drifting issue
RParker762
Glendale, AZ
Just as the title states, my Mavic Pro Platinum has started drifting. Sometimes up sometimes down, sometimes left, sometimes right. Did a controller calibration first, took several tries to get it to work without timing out. Still drifts. Did an IMU and compass calibration and it still drifts. And not little drifts either. Probably a foot every 2 seconds. Did have a hard landing from about 2' a while back and messed up a prop. replaced it and all seemed fine. Hard landing was my fault as I was in atti mode, inside a building and was not thinking about it and when I tried to land, it just dropped. My Care refresh is up next month so I was wondering if I should send it back and see if they can fix it, if not get a replacement or does the group have any thoughts on the issue?
*Edited to add - had 23 sats at launch and throughout flight*
Flight logs. Hopefully I did this right.
perhaps try replacing the other three props As well. Seems an improbable fix, but certainly worth a try
CMDR DV TEARDROP
