Wher can I find a USB to RC cable that will charge the remote controller for a MPP? The normal micro USB cables do not work
The female side on the RC seems to be rectangular, unlike the usual USB cables, which are trapezoid, resulting in a dodgy connection. I presume it is a DJI bespoke thing?Any micro USB to USB cable will do the trick. Lots of android devices use/used the same cable.
Yes, it appears to be rectangular. Any Micro USB cable will fit though. Make sure you're attempting to connect it properly so you don't damaged the port.The female side on the RC seems to be rectangular, unlike the usual USB cables, which are trapezoid, resulting in a dodgy connection. I presume it is a DJI bespoke thing?
Many thanks. Will get one, and reduce the risk of wrong connection by anyoneYes, it appears to be rectangular. Any Micro USB cable will fit though. Make sure you're attempting to connect it properly so you don't damaged the port.
Another option would be to use a reversible Micro USB cable (like this one) so you can insert the cable into the Micro USB port in either direction. I own that cable and haven't had any trouble using it.
