My image is not level
minimpw
Minnesota
My image is always a slight higher on the left side. I calibrated it out of the box. Any thoughts?
Thanks in advance
I know this sounds like a dumb question but you calibrated it on a level surface correct?
Reactions: minimpw
It sounds like you may have done a compass cal which has 0 to do with the gimbal. People have also had luck with an IMU cal when their horizon is off.The manual is a truly valuable resource to refer to. :)There is also a gimbal cal, but what cobra was referring to is a roll adjustment you can do in flight to adjust horizon.
Reactions: minimpw
I just did the calibration where you turn it vertical and horizontal. Is there one specifically for the gimbal?
Yes; there is a different calibration for the gimbal.
Jerking it around will throw your horizon off. I've found flying it steady helps as well. It does adjust itself after calibration. So before jumping to conclusions always fly it around after. Certain things actually may not look level at different altitudes
genoavoles
