- Joined
- Jun 21, 2020
- Messages
- 3,977
- Reactions
- 3,963
I like my Mini 3 pro but there are moments, even in Cine mode when I felt it wasn't as controllable as I'd like. I've got the pitch and yaw and speed/smoothness settings pretty much where I want them. Fore aft movement generally hasn't been an issue for me as when going forward we can rely on the camera to help us navigate. It's side to side movements that always spooked me. I thought that perhaps, at least in Cine mode I would make things more predictable. But the settings were kind of a surprise.
What always bugged me about side to side movement is that if I got just a little too heavy on the right stick the Mini 3 would just SHOOT right or left, far faster than I intended. I had to be so gentle on the stick and though I had it set to the gentlest setting, but to no avail. Perhaps I had it backwards? So I inverted the settings for right and left movement. And to my surprise there was no change!!! Any fast movement of the right stick, right or left the Mini 3 wouldmake an abrupt movement.
To my surprise, what seems to work the best for me is when the EXP settings are straight-lined on the curves. The drone can still be a little more abrupt than I think it should be relative to stick movement, but at least there is more subtlety than if the curves went in either direction. Strange, no?
Has anyone else played around with the EXP settings, particularly in the Cine mode?
