ND Filter - the choice of one....
Paul Iddon
Preston, UK
So, if you had to get a single ND filter for the Mini 3 Pro (not a set of 6 etc)., which would you get?
ND16, ND32, ND64, and so on?
I'd buy an adjustable filter (like this K&F filter) so one filter could be used in place of several.
Maybe choose which conditions you fly mostly in.
I use a nd/pl 32 mostly
ND FilterConditionsOld Exposure TimeNew Exposure TimeShutter speed
ND2At dawn or dusk1 sec2 sec1/
ND4During overcast or cloudy days1 sec4 sec1/250
ND8Partly cloudy conditions1 sec8 sec1/500
ND16Partly cloudy but mostly sunny conditions1 sec16 sec1/1000
ND32Sunny and clear conditions1 sec32 sec1/1250
ND64Extremely bright conditions with reflective surfaces1 sec1 minute1/2000
if i couldn't get a variable I guess I'd get a 16. I probably have used that more than any of the others. If I wanted to do hyperlapse it might be 512 or 1000.
Very nice, with glass elements. Looks like this company makes quality photography gear. But I do like having the polarizer also, might be a tricky design with a variable ND. Of course, maybe the design is just cross polarizing so that might be inherent. I see they have them also for the m3 but not the m3 classic yet.
Reactions: Paul Iddon
Shouldn’t the shutter speed values be in the other order, as you add more and more neutral density filters, the image gets darker and if the aperture remains the same you need longer exposures to get the same light.
These are fixed shutter speeds that would be required with no ND Filters in those conditions
1. Are you shooting video?
2. What’s the weather like in Preston?
Here in overcast Western Oregon, my default is an ND8. I often pull out the ND16 in broad sun, and occasionally a 32 or 64 for beach or snow.
There is no fixed ND filter for all seasons and reasons; I’m mounting an ND specifically for conventional motion blur in video, or, extreme motion blur as an effect in stills.
This is helpful! It’s probably not got the best accuracy for a specific location, sun height, and weather, but it shows the weather trend vs. available light and starting filter in an easy to understand way.
I saw that, but it weighs 1.1 which would take the drone over 250...
Paul.
Have you weighed your drone? It’s in a 249g class, but that isn’t the same as it weighing 249! My Mini 2 is also “249g”… except on the scale, where it’s 238g.
I myself haven’t used a VND on a drone - no comments to share.
But, why this question? Is there something specific you want to get out of using an ND, is there some reason that one ND filter to do it all seems a good choice?
Ah thanks, my background is way back to film photography and working in darkrooms and we would only use ND filters if we wished to slow down the shutter speeds(like taking photos of water flowing where given a really slow shutter, the water became blurred like a fog) now with the 180 rule the shutter speed should be at least twice the frame rate, so as you add on more filters either the shutter speed must decrease or the aperture increase to get perfect exposure. Since the drone is ‘usually’ flown some distance from the object and depth of field is of less concern, is it better to change the aperture rather than the shutter speed and hence frame rate? Or am I missing the point here and that ND filters are mainly used for photographs rather than video.
And thank you for answering my question, I appreciate this. I am not being a troll here. I really want to know why ND filters are the must have item, where I would have thought that polarising filters would be more important for changing the sky and reflections on water, (something that as a drone photographer would be so important considering it’s position.)
Thanks again
Mike
Thanks again
Mike
ND filters are mainly used for video to conform footage to the 180-deg rule, producing conventional motion blur. However, their use is debatable even there, as most drone video is of the slow, wide, and scenic variety, and conventional motion blur won’t even be perceptible on a still frame from typical video.
Most drone cameras do not have variable aperture, so, the only available exposure controls are ISO, shutter speed, and any filters.
Most drone cameras have small-ish sensors and are used at focal lengths and subject distances where shallow depth of field (DoF, depth of focus) is never going to be available as an effect. This too is pretty different than conventional terrestrial photography.
ND filters for stills are therefore not used to support wide apertures for shallow focus, but are sometimes used for blur on water, blur on moving objects or blur on camera movement. More of an effects approach, and different than the goals for motion blur in video.
ND filters are not a “must have” item, but manufacturers want you to buy them, retailers want to sell them, influencers want to talk about must-have stuff, and purchasers want to justify their investments. To be clear, I’m a purchaser with a wide range of ND for my own and my employer’s drones.
***edit***
!!!Collect them all!!!
Thanks - I have ordered this K&F one.
The weather in Preston (UK) is quite varied - so the one I have ordered above would probably be fine. I shoot video - but will take photos.
I did weigh my drone and it's 247g without the gimbal cover on, so a 1.1g filter should be good.
Paul.
Mike
Polarizing fliters (PL) are problematic on drones for two reasons.
First, cameras on drones are mostly wide angle, with diagonal angle of view between approx. 75 - 84 degrees. As the polarizing effect is strongest with the sun in a certain angle to the lens, photos with blue skies tend to look ugly with a PL-filter, with half of the sky dark blue and the other half much lighter. If you try stitching such photos for a panorama it will be terrible.
Second, as everybody with experience from photography with PL-filters will tell you, you need to rotate the filter depending on the angle of the sun and lens to get full effect. That is a bit difficult when the drone is mid-air.
ND 16. Unless it's stupid bright out (high noon stupid bright out) an ND 16 covers most cases involving the sun for me.
Thanks again
Mike
I dont do video, but I do use ND Filters. Sometimes you want that blur effect either with the clouds or water. I use the 32ND a lot but for blur I go with the ND1000. Manual adjust the shutter speed then increase or decrease iso. Most of the time for water blur, I start setting the shutter at 2 sec. ND1000. Then look at exposure. Most of the time I get away with 100 iso which is what I want.
kaidoestech
