Need Help. Almost broke my Mavic!
PelagicPilot
I recently received my Mavic 2 Pro, and I was excited to fly my new drone. I unboxed the Mavic, and unfolded the top wings without issue. I then proceeded to attempt to unfold the other set in the same direction, until I had realized my mistake. I thought that the bottom set unfolded in the same direction as the top set. I didn’t end up breaking anything, and there is no damage, however I have found that there is some horizontal play within the bottom set of wings. There is about 1-3 mm of movement at the propeller end of the wings. Would anybody be able to check their own mavic to see if this play occurs in their units as well, as I am wondering if my mistake caused this, or if this is normal. If anybody could help it would be great. Thanks.
Reactions: charliesRig
There is some amount of movement. To what dimensions, I don’t have anything with me at the moment to measure with any accuracy. Your one to three is probably close, but three may be a bit much.
thanks for that I didn't know...
My mavic pro 1 has no slop once the arms are extended
....cR
kkanoz86
