Need help
Takeflyt215
If anyone can help please i keep having issues with distance. I fly up about 250 ft i lose signal and if i fly out about 900 feet i lose signal and i was at at a soccer field the first time and today i went to what seems like an open area like a huge lake barely trees and still the same thing. Is there a setting i need to change im lost this is a new mavic
Try pointing the antennas straight up like the joysticks, and try to keep the DJI logo always facing directly at the Mavic. The signal is strongest going out from the flat faces of the antennas.
Thanks for the response I tried that and unfortunately still get the same results.
Well its probably either there is interference (which you could test by going out into the wilderness), or a defective product. Hard to say which without having access to another Mavic to compare.
Reactions: Takeflyt215
Its definitely not working right I'd call DJI and RMA it..
Before doing anything, I'd recommend uploading your flight info to airdata.com and linking to it here.
saskia
