Just been gifted a brand new
Mini 3 so really looking forward to reading up and getting some tips from the forum.
mavicpilots.com
Since you live in the UK, there are specific laws and rules for you to follow, I read your 2nd posting that you have fulfilled your legal obligations, Good on You!!! But here is the link to CAA in case you need it for reference…
Find out what you need to know and do when you fly drones or model aircraft in the UK
register-drones.caa.co.uk
Remember that YouTube is a valuable resource for your
Mini 3, many of the posters have some really great advice and it's easier to follow when you can see the settings verses just reading about them… But I am still Linking the User Manual at the end of this post…
Since you are new, here is some Good Old Fashion Advice…
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the
Mini 3, including the User Manual.
Learn and download DJI
Mini 3 related apps, software, and manuals at the DJI Download Center
www.dji.com
Fly On and Fly Safe…
