New from Northern California Foothills
Caffeinator
California. USA
Hello all. I'm located in the foothills in Northern California around Colfax. I am a disabled USAF veteran currently working in I.T. for Yolo County. I plan to retire in about 3 years, I'll be 60. I purchased my Mini 3 Pro about a year ago. I've flown around my home and some other areas, but recently a buddy has turned me on to getting certified and going into business with him. I'm currently watching training videos to help pass the 107 test. The mini is fun, but I've told my wife if when I pass the test, I'm going to be looking at getting a used Mavic 2 Pro or better yet a 3 with hopes for Cine version. I've been into photography for some 40 years and this seemed like a natural progression for me. Any members around the Roseville, Auburn, or Colfax areas? I'd love to meet up and learn from others. Chris
As you stated above, Me Too…
As a somewhat New Drone Pilot, there maybe a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs less than 250-grams (0.55 pounds), and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
But once you acquire your Part 107 and if you use the Mini 3 in your work, if must be registered and transmit RID…
Since you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in California, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Fly On and Fly Safe…
Cant help from Illinois, but thanks for your Service to our Country!!!
Reactions: LoudThunder
Great choice of alternative career. Will be loads of fun and good luck with the 107. Thank goodness we don’t have to do that here although we do have A2Cof C
From a bit NE of Sacramento - @Caffeinator - Thank for joining us @ MP!
From a Navy veteran, thank you for serving our country!
Our daughter lives in Reno, so I get to pass by Colfax coming and going!
stephy_gl
