New Member and New to Drones
dougt24
Utah USA
I purchased the DJI Mini 5 Pro Combo Plus package which should arrive this coming Friday. I am older, 71, from Utah USA, and retired. I do a lot of 4x4 jeep off-roading exploring scenery, ghost towns, Native American ruins, old mines, etc.. I purchased the drone to help scout out trails and canyons. Looking forward to learn to pilot the drone and seeing the world from a different perspective.
Welcome to the Hobby and to the Forum!! This is one of the Best places on the net to get started and get the answers you need as you progress!
Welcome from Bakersfield!
If you are a New Drone Pilot, there are a couple of Legal Things you may need to do…
First, if you have not already done so and you want to fly your drone recreationally, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). This Link is to the Pilot Institute Web Site where you can get your TRUST Certificate. (FREE…)
Your Drone weighs more than 250-grams (0.55 pounds), and even while you are flying under The Exception for Recreational Flyers, you are required to register your Drone. This link is to the FAADroneZone where you can register your Drone. The cost is $5.00…
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Utah, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
You paid a lot of money for that Drone, put your phone number on it. If your Drone gets lost or stuck in a tree and it finally comes down when you are not around, give the finders an opportunity to contact you so it can be returned.
If your Drone's Controller needs a Phone/Tablet to work, plug it into your Controller; turn on the Controller and start the App if it does not start on its own. On the Drone, open the front legs and the back legs, then remove the Gimbal Cover.
Turn on the Drone and watch it come to "life." Watching the Gimbal go through its self-check is almost like watching a puppy or kitten opening its eyes for the first time…
Place the Drone down preferably on a Landing Pad while it finishes its self-test (collecting satellites if it has GPS, etc…).
Check your Battery Status (Phone, Drone, and Controller), check the Signal Strength, by now the Controller should have reported it updated the Home Point if GPS capable.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home Point Updated (if the drone has GPS).
If you go out in a rush and race thru your start up and take off before the Drone has finished it prep, it may update its Home Point over that pond or that old tree you are flying over and in your excitement, you'll fly the Drone long past it Low Battery point and when it engages Return to Home and lands in the pond or in a tree; it will be all on you…
Now go have fun, learn to fly the Drone by sight before you try to fly it out a distance depending on the video feed, FPV.
Fly On and Fly Safe…
Reactions: dougt24
Thank you very much for this information. Very useful to me. I did acquire TRUST certificate and plan to register the drone with the FAA.
devonwalterslee
