New Member from Ireland
Mr Blue Sky
Ireland
Hi Everyone
I registered for this forum late last year but have not posted until today. Its nice to be amongst others who share a common interest and I look forward to using this forum and possibly helping others along the road. My main use of my Mavic Pro 2 is to record classic cars at runs and shows around the Irish countryside.
Until again...
Since you live in Ireland, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Mavic 2, including the User Manual.
Fly On and Fly Safe…
Welcome to the forum! :)
Hi Everyone
Until again...
ELO fan?
sscott062
