New Member from NE England
Welcome to the forum! :)
I’ve just joined this forum. I’m from North East England, near Newcastle-upon-Tyne. I have mini 3 pro.
Since you live in the UK, there are specific laws and rules for you to follow, please check to ensure these are current.
You did nto mention your experience, but since you are a New Member, I will guess you are new to Drones… Even if you have flown Drones before, here is some Good Old Fashion Advice…
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Fly On and Fly Safe…
Hello everyone. I’ve just joined this forum. I’m from North East England, near Newcastle-upon-Tyne. I have mini 3 pro. Look forward to discussions in this forum.
An Aussie welcome to the forum, my next-door neighbor has an apartment in Hartlepool, I fly a Mavic2 Pro, Sunshine Coast Qld.
SerenaKuvalis
