New member from New Jersey
roby17269
New Jersey USA
Hello all, I have just joined thanks to a link on a dpreview forum.
I have been a hobbyist photographer for years now shooting DSLR and mirrorless cameras for fashion, travel and family.
I have been NOT interested in drones for a long time, till the end of 2022 when a friend showed off his Mini 2 :)
After that I decided to buy a Mini 3 Pro and had a lot of (scary) fun with it. Last summer I have added a Mavic 3 Pro and I love it. I wish I could use the new RC-2 with it though.
I use my drones occasionally for recreational purposes only. So far so good :cool:
I had one small crash with the Mini time ago :eek: . No damage to the drone (apart from the propellers), but a lot to my ego, since I was showing off in front of my daughter's class. Oh well.
Thank you everyone!
"since I was showing off in front of my daughter's class" OMG!
I have never done anything like that. :rolleyes:
I think it is a human thing?
BTW, I'm one of the most goofy members here.
BTW+1, Welcome to the Forum!!
Rod ..
Rod ..
That was my 3rd flight - I think I am a bit better now ;)
But yes it was mightily embarrassing
Thanks for the quick reply!
So don't do it again, well maybe after I do. :)
I won't post it here, I send you a PM. 👌
Rod ..
From your posting, I am going to post like you are a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs less than 250-grams (0.55 pounds), and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com trust.pilotinstitute.com
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in New Jersey, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Fly On and Fly Safe…
Welcome to the forum! :)
LoudThunder:
Thank for making this great, quick-start tutorial available to new members and new pilots. There is so much to learn.
Safe flying.
Phillip
Thanks for all the info! for basic things I am good... meaning I have registered my drones (and attached the Pilot Institute's stickers on them), and have received my TRUST certificate.
For now I am flying in daytime and only for recreational purposes, so I will postpone the Part 107 license as much as I can ;)
nikt_elo
