mavicpilots.com
You did not mention if those drones were new or used… If they are used, I hope the drones were unbound from the original owners accounts… If you do not know what I am talking about and the drones are still registered to the original owners, then you might want to return them as they will never really be "your drones…" It's like selling a used car and not turning the registration and title over to them… If the Drones are new and you can pretty much ignore all that I have written… If not Google unbinding a DJI Drone…
I cannot advise you about insurance in the UK, but you might try asking your home, apartment, car insurance about it. A lot of insurance sell hobbist insurance but you have to get a lot more serious if you are going to be commercial about it…
Since you are new to drones, here is some Good Old Fashion Advice…
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Fly On and Fly Safe…
