New Mini and Mavic Firmware Update v01.00.0300 (August 14,2025)
wailermon
The DJI RC firmware v01.00.0300 appears to be part of a broader update cycle for DJI's Mini and Mavic series, though specific details for the Mavic 4 Pro RC firmware under this version are still emerging. Based on related firmware notes and community reports, here’s what’s likely included or associated with this update:
🎮 RC Firmware v01.00.0300 Highlights​
  • Improved Compatibility: Enhances pairing stability between the DJI RC Pro 2 and newer aircraft models, including the Mavic 4 Pro and Mini 4 Pro.
  • Refined UI Elements: Minor interface tweaks for better responsiveness and layout clarity, especially in camera and flight settings.
  • Bug Fixes: Resolves intermittent connection drops and improves firmware sync reliability when updating via DJI Fly or Assistant 2.
  • Battery Sync Enhancements: Ensures more accurate battery telemetry and compatibility with newer battery types.
🧩 Related Aircraft Firmware​
This RC firmware often pairs with aircraft firmware v01.00.0300, which—on the Mini 4 Pro—introduced features like:
  • Auto mode for ActiveShots 360°
  • Vision Assist and Obstacle Sensing toggles
  • 3x digital zoom in 12MP photo mode
  • Support for DJI Goggles and Motion Controllers
While not all features may apply to the Mavic 4 Pro, DJI tends to roll out similar enhancements across platforms when firmware versions align.
🔧 Post-Update Settings to Verify​
🛫 Flight & Safety​
  • Obstacle Avoidance Mode: Set to Bypass or Brake depending on flight style
  • Return-to-Home Altitude: Adjust for local terrain
  • Max Altitude & Distance: Confirm within legal limits
  • Vision Assist: Enabled for low-light or foggy conditions
🎥 Camera Settings​
  • Vertical Tilt Range: Test new angles for vertical shooting
  • Digital Zoom: Confirm 3x zoom in 12MP mode (Mini 4 Pro)
  • Color Profile: Choose D-Log M or Normal based on workflow
  • White Balance: Set to Manual for consistent footage
📡 RC Controller​
  • Button Customization: Assign C1/C2 for cruise control or gimbal reset
  • Screen Brightness: Adjust for outdoor visibility
  • Firmware Sync: Confirm RC and aircraft versions match
  • Battery Telemetry: Check for accurate voltage and cycle count
🧪 Test Flights​
  • ☐ Hover test for motor vibration
  • ☐ ActiveTrack subject framing accuracy
  • ☐ Cruise control smoothness
  • ☐ Signal strength in typical flight zones
🗺️ What’s Included in FlySafe v01.00.01.38​
  • Updated Geo Zones: Reflects new temporary flight restrictions (TFRs), no-fly zones, and controlled airspace boundaries.
  • Authorization Sync: Ensures LAANC and custom unlock certificates are correctly applied to your drone and controller.
  • Improved Launch Permissions: Prevents failed takeoffs in restricted zones by syncing the latest safety data before flight.
🔄 How to Update​
If you're using DJI Pilot 2 or DJI Fly, here’s how to update the FlySafe database:
  1. Power on your drone and RC.
  2. Connect the RC to Wi-Fi.
  3. Open the DJI Fly or Pilot 2 app.
  4. Tap the Geo Zone Map or FlySafe Database button.
  5. Tap Check for Updates.
  6. Follow prompts to install the update.
  7. Power cycle both drone and RC after updating.
You can find a full walkthrough on Propeller Aero’s support page
Reactions: GadgetGuy
Might want to clarify the title and any crossposts with correct models as that sounds like it's for the Mini 1 and Mavic 1, which would be very surprising.
Tripatsas
