New Peterborough pilot👀
Peterborough, UK
Hi guys,
Thought I'd introduce myself and say hello, I'm from Peterborough, Cambridgeshire in the UK and currently have a broken (thanks to loosing all satellites and the closest tree getting involved) Mavic Mini. I'm also looking to turn my work and hobby into a YouTube thing as well (already got 1 video) once I've ordered some new propellers today and fixed it😂
Hi guys,
Welcome…I’m also from Peterborough if you like you can check out my videos of the local area. I only have a small channel but I’m hoping to get out when the weather gets better, and hopefully grow the channel , I have a mini 2 so wind is its worst enemy. @CameraintheskyDji
Since you live in the UK, there are specific laws and rules for you to follow, please check to ensure these are current.
You did say that you lost GPS then You flew it into a tree so, you might need some training in basic flying with no video, as they say in Atti Mode… So, here is some Good Old Fashion Advice…
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Mini, including the User Manual.
Fly On and Fly Safe…
sscott062
