New Pilot - Australia
danwnz
Brisbane QLD, Australia
Hi all,
My name is Dan, I am new to drone piloting, have flown radio controlled Heli's before. I have the DJI Mavic 3 mostly purchased for photography, but will get some great use from the video as well. Loveing it so far, have been doing some technical flying to learn how the drone behaves in wooded areas with obsticles around, low battery control...
I look forward to chatting with you all and learning from your experiences and sharing some of my own.
Greetings from Birmingham Alabama, welcome to the forum!
Hey Dan,
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
Since you live in Australia, there are specific laws and rules for you to follow, please check to ensure these are current.
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Happy, Safe and Legal Droning…
@LoudThunder Thank you so much for the valuable information. You are so right about the manual, I have picked up some things today through this forum contained in the manual that I had missed.
I actually followed one of your other posts on a USA users Introduction and completed the USA TRUST certificate so when I travel over there I am part way there to flying there.
Did the knowyourdrone quiz from the CASA website while charging the batteries for the first time.
Also watch lots of videos on youtube danstube.tv had some really great info, and he lives near me it would seem.
I get an oops page when clicking the map page you shared
Reactions: MA2 317
Thanks, by the way, I knew it was out and I had notified the Web Folks about the Member's Map, it has been out a week or so. I hope they can get it back on line...
Welcome to the forum! :)
Welcome to Mavic Pilots! 🙂 Enjoy the forum!Thumbswayup
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
I asked about this and the answer to my problems was that my Google Chrome Web Browser had the Location turned off. I don't believe that I inadvertently did this, but it was turned off. If you are having the same issue in Google Chrome, I recommend you Google "turn on location is Google Chrome" and you will be given the instructions to enable it. Actually, it was enabled in mine, but disabled by web site, so check these also...
Reactions: GFields and danwnz
Hi all,
Welcome, mate. I’m in the Northern Rivers of NSW.
Awesome thank you for finding out about that, yes was using chrome and typically deny most privacy or notifications in browser
famagusta
