New Pilot Check-In and Waypoints/Hyperlapse Question
BlueSkyFlyGuy
Atlanta, GA
Site
creativesources.com
Greetings Mavic Community, new member here as of today. Only been a pilot for a few months, so forgive if I ask familiar questions. Haven't found a reference to this question yet in the threads. I've been enjoying the precision of setting waypoints for video flights, very cool and productive. Having saved a few of the waypoint routes I've flown, I would like to use a saved waypoint file to fly a hyperlapse run with the saved coordinates. Can one convert a video waypoint route to a hyperlapse waypoint route?
To answer your question, not that I’m aware of.
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live Georgia, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Fly On and Fly Safe…
Welcome to our forum, from Hauptmann, in Hurst, Texas!
You'll love the flexibility of vantage points an aerial camera platform affords--you'll get shots and videos you could only dream of before! I fly a Mavic 2 Pro now, but will soon add a Mini 3 Pro to my “fleet”.
Wish I had an answer to your question. I'm confident someone will. We have over 150,000 members—many from your part of the South--who enjoy helping each other get the most out of our hobby. Most of the questions you'll have will’ve already been addressed, and are easy to search. If you have NEW questions, just ask!
I attached a couple of links below, which will make learning piloting and photo/video skills easy. They specifically refer to the Mini 3 Pro, but his “moves” apply to any drone (DJI, anyway).
Glad to have you with us!
Rich R (aka Hauptmann)
Welcome.
"hyperlapse waypoint route" ?
I really don't think that most of know what that is, lapse word made me think of video.
I tried you link, "http://https/www.creativesources.com"
As you can see there is a link problem.
Anyways, I would like to see your stuff with a Mavic.
And set up signature with what your flying.
Other then that..
Just to make sure, Welcome to the Forum
Rod ..
Welcome.
Other then that..
Rod ..
There is nothing wrong with his link. You have it typed in wrong. You have http://https: leave the first http: off and try again.
Fixed the link, working now. Thanks to RodPad for the heads-up. Since I'm a newbie pilot, I've yet to put my drone work up. Been shooting architectural images for a couple hundred years, but you'll have to stay tuned for the drone portfolio...
"Been shooting architectural images for a couple hundred years,"
Hum, It's your thread, I will just be watching for your stuff. 👌
Rod ..
With the Mavic 3 there is no way to convert a normal waypoint mission into a waypoint hyperlapse mission using DJI Fly. Unless you feel like performing some exploratory work in DJI Fly's file storage and then some XML wizardry, you will need to create a separate waypoint hyperlapse mission.
The only other option is to experiment with setting up a photo interval every second or so (if that is possible with DJI Fly) and then fly your waypoint mission as the drone is taking photos. Of course, if you capture a series of images this way, you will have to convert the series of images into a hyperlapse using other software.
Welcome to the forum! :)
Welcome from England UK. I’m not aware of any way to do that.
Greetings from Detroit.
cbooth
