New pilot from Edinburgh Bonny Scotland
Welcome to Mavic Pilots .
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Welcome from the Hampton Roads area of Virginia, USA. I am a Mini 2 Flyer and I know the excitement of flight. So, if I may offer some advice.
Below is the link to all of the downloads offered by DJI for the Mini 2. You will also find the 75-page User's Manual, in case your Drone did not come with one. The User Manuals are published in different languages.
DJI Mini 2 - Download Center - DJI
Happy and Safe Droning…
Thanks for the welcome and I look forward to learning as much as I can to make me a better , safer pilot and how to get the best out of my drone 👍👍👍
tagir
