New pilot from Hong Kong and interested in drone still photography
Nice shot. Great composition. I'm also really interested in the photography end of it, and the drone is great for getting unique vantage points. It's like having a 400 foot tall tripod. Always up for a chat about photography. Welcome, and look forward to seeing more shots. :)
Recently I got a lot of ideas from this video:
P.S. I recently posted some photos in the "Photos and Videos" section of this forum, so if you're curious go check them out. Most of those were taken with a Mavic 2 Pro, which is basically the same sensor as the one you're using in the Air2S.
Reactions: LoudThunder
Hi all, I am a new member greeting from Hong Kong. Not only new to the forum but also only pick up drone flying recently with an Air 2S. My main interest is to take aerial photos from birds' view more than filming. Wish to share and learn here in the future.View attachment 178413
Welcome from the Midlands of England.
Very cool pic, can I ask where that is?
Reactions: sarahb and MA2 317
Since you live in Hong Kong, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Air 2S, including the User Manual.
Fly On and Fly Safe…
Reactions: MA2 317 and Erk1024
Jeshirley_Koi
