New Rules Mavic Mini2 in Sweden
horntoad
Sweden
Hello
I'm considering purchasing a Mini2 here in Sweden but am a bit confused on what the rules are for this size and weight drone. I believe the pilot must be registered but is the study material and test for a drone card also required?
Thanks
curt
Reactions: slup
Hi there fellow countryman & welcome to the forum ? :D
As you're querying the Swedish regulations I will point you into the right direction below ... better that you learn where all are as the regulations might change over time.
-Start out with this page --> Drönare - Transportstyrelsen which is kind of a portal page to all drone related in Sweden.
-Here you have a guide to find out what concerns you & the drone you have --> Drönarsidan
-Then as you know from Jan 4-2021 it became mandatory to register as a drone operator & for some drones to take a web test & register, you do that here --> Drönarsidan
-And here you have the transition regulations valid until Dec 31-2022 --> Övergångsregler gäller 1 januari 2021–31 december 2022 - Transportstyrelsen
Below a simple (official) process map over the regulations from today -> Dec 31-2022 & what they will be after Jan 1-2023.
(Click on it to make it larger)
Reactions: Crashdummytest
Marcelo OKunz
