New streamer for smart controller
Oldmanoftheworld
UK
Purchased for a particular use in the field. The idea is so I can stream the drone footage live to a separate high brightness monitor and also allow clients to see live footage. Not been able to test yet as I’m still waiting for hdmi leads. It will also stream via its own network to any iOS device.
Have you tried the Anycast since latency is not that important ?
It's quite a bit cheaper
You could also try the Appowermirror app direct wireless connection between the SC and a larger tablet for viewing, then you don't need any other equipment.
It doesn't need a wi-fi network just the transmitting device having a hotspot running that the receiving device connects to.
All you need to do is install the app on the receiving and transmitting device, connect the receiver to the hotspot and then run both apps, hitting transmit and selecting the receiver device.
You may need to side load it on the SC from the apk.
For the side load
Reactions: TampaTC
Q14
