New to drones and interested in VR videos
got2golf
North Carolina
Hello, I am relatively new to drones and have an interest in creating VR videos. I have purchased a used Phantom 2 and several VR video cameras and attachments for the drone. I have learned a lot from this forum and will assemble my rig when I get back from an extended vacation. I am on a budget so much of my equipment was purchased used some requiring repair so I am big on DIY equipment repair. I am an old computer geek so I have lots of computer experience and have a video-processing desktop already set up. I also plan to do underwater photography using my cameras. I am also learning AI just as an aside.
Welcome to the forum! :)
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs more than 250-grams (0.55 pounds), and even while you are flying under The Exception for Recreational Flyers, you are required to register your Drone.
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com trust.pilotinstitute.com
Since you are planning to monitorize your videos, you probably need to acquire your Part 107 License, here is a link to get you going…
Since you live in North Carolina, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Fly On and Fly Safe…
Freemaximalis
