New to Drones
jordanka16
Oregon
Hello everyone, I am a mostly amateur semi-pro photographer who bought a Mini 2 on a whim, and instantly fell in love with drones, the shots they let you get, and just the fun of flying in general.
I loved it so much I've signed up for my part 107 license test, and I bought an Air 3, mostly for the telephoto lens, and better battery life and wind resistance. So far I've had a lot of fun playing around with what it can do, although my cinematography skills need some work.
I'm excited to be a part of the forum and continue learning about drones. I'll also share this photo from above my house.
Nice photo@
Oregon i5 coridor?
"Florence" ?
The best ATV dunes are at Winchester Bay. :rolleyes:
Been there many times. Thumbswayup
BTW
Welcome to the Forum!!
Rod ..
Welcome to the forum! :)
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Mini 2 Drone weighs less than 250-grams (0.55 pounds), and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
But your Air 3 Drone weighs more than 250-grams (0.55 pounds), and even while you are flying under The Exception for Recreational Flyers, you are required to register your Drone.
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com trust.pilotinstitute.com
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Oregon, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below are the links to all of the downloads offered by DJI for the Mini 2 and Air 3, including the User Manuals.
After you read the Manuals, read them again, you will be surprised what you missed the first time and you will be better prepared for that first "scary moment…"
Fly On and Fly Safe…
explorjus
